Toyota Camry engine light to stay on after you had replaced and oxygen sensor
What would cause a '99 Toyota Camry engine light to stay on after you had replaced and oxygen sensor in Bank 1 sensor 1 location. Does it need an air flow sensor if it is a '99 Toyota camryV6?
_________________
I love my Camshaft Parts!
"You win some, lose some, and wreck some."- Dale Earnhardt Sr.
_________________
Get the trouble codes read out again and determine if it is the same sensor code.
What brand of sensor was used and was the correct sensor replaced. The engine has more then one sensor.
Sometimes using a Bosch brand or what is called a "universal sensor" can cause problems.
appleredcamry
06-14-2009 07:06 AM
