Variable Valve Timing Gear
Old 09-23-2015, 08:18 AM
Andrew Mckenna's Avatar
Default Variable Valve Timing Gear
Does anyone else have a probably when you cold start your vehicle in the morning you motor sounds like it does when you first get you oil changed and it rattles really bad. That's what mine sounds like every time i crank my car cold. I was told it was that little gear. Just wanted to know if anyone else was experiencing that.
Old 09-23-2015, 07:03 PM
What engine do you have?
Old 01-01-2016, 10:49 AM
75gl1000's Avatar
I have a v6 2001 that sounds like the same problem
mkv_camry
12-30-2011 12:29 PM
deejayphilo
02-20-2011 02:43 PM
Velas
07-19-2010 03:55 PM
larrym
01-08-2008 11:22 AM
camrycoupe
09-03-2007 12:12 AM
Quick Reply: Variable Valve Timing Gear
