Sponsored by:
Sponsored by:
02 camry with rough idle/stalling
Old 02-22-2008, 08:08 AM
slvrspec8's Avatar
Default 02 camry with rough idle/stalling
ive got an 02 camry that for some reason will start up fine but will somtimes die intially after start up or when stopping at a light or stop sign. i changed the spark plugs, changed the oil, did fuel injection cleaner, changed the air filter, checked the battery and alternator and the car still has the problem can anyone shine some light on this problem??? someone also told me i may need to regap the plugs as i did not do this when i put them in anyone also know the gap for these cars plugs? i was also thinking it could possibly be a bad iacv. one last question would be do these cars come with any type of idle relearn that can be done with the foot and key sequence?
Old 02-22-2008, 11:25 AM
Default RE: 02 camry with rough idle/stalling
The IAC valve may need cleaning. If you remove the air intake hose from the throttle body and look in at the throttle plate, you should see a large air intake slot for the IAC.
Spray some cleaner in the area or remove the IAC and clean it. Use only a cleaner that is safe for plastics (read the labels or ask the auto parts person).
Old 02-23-2008, 10:59 AM
gutierrez_er's Avatar
You might also look into cleaning the EGR (exhaust gasrecirculation valve), were the old spark plugs bad? theremight be a high buildup of carbon residue in the EGR causing the problem.
Old 02-23-2008, 06:36 PM
05cam's Avatar
try as mentioned above. clean the iac valve out by removing intake hose and spraying a cleaner. something like throttle body cleaner will work fine, i like seafoam. Id say seafoam it all
Old 06-27-2009, 04:08 AM
cirbyboy's Avatar
where is the IAC located on the 2002 camry 2.4??
Old 06-27-2009, 05:49 AM
pedro's Avatar
At the throttle body.
Old 06-28-2009, 03:12 AM
cirbyboy's Avatar
I called the dealership (which i should have done in the first place) and they said that the 2002 2.4 liter camry doesn't have an IAC because it has a throttle positioning sensor and a throttle body sensor.. which i thought was stupid.. But at least im not crazy for not finding it.. haha
Old 06-28-2009, 05:54 AM
pedro's Avatar
Not sure I understand the dealer's reply. Who did you ask, a mechanic or one of the "service advisors"? All the fuel injector engines I have seen have a TPS and "throttle body sensor" (probably a MAF) AND an IAC. The TPS sends signals to ECU to control fuel and the "throttle body sensor" also sends signals to control fuel - neither will regulate idle as far as I understand.
Old 08-07-2010, 09:08 AM
84runner's Avatar
slvrspec8 - so whatever happened, did you solve the problem? I have the same symptoms in my 03 2.4L AT.
holysabre
03-23-2012 10:00 AM
chinik
02-13-2008 04:54 PM
carmine34
11-02-2007 12:03 PM
jmhowe
10-24-2006 03:49 AM
green97le
06-08-2006 12:32 AM
Quick Reply: 02 camry with rough idle/stalling
