Sponsored by:
Sponsored by:
07 Camry Auto Window Down Switch
Old 11-18-2007, 07:14 AM
StoreKeeper's Avatar
Default 07 Camry Auto Window Down Switch
On mine the window "Driver Side" will go down when you push once, but to go up you have to hold it until the window is all the way up.
Anybody heard of a "Mod" that will Auto for both Up and Down?
Thanks in advance
Bruce/StoreKeeper
Old 11-18-2007, 12:56 PM
pedro's Avatar
Default RE: 07 Camry Auto Window Down Switch
Auto up is a safety no-no, especially if you have kids.
Old 11-18-2007, 07:41 PM
No Children here.
I had it on my 06 G35 Coupe
Rx Bruce
Old 11-19-2007, 07:40 AM
pedro's Avatar
If the auto-up on your G35 was factory installed then I'll bet it had an auto-reverse (or stop) function if it detected resistance before it fully closed. Similar to the auto-reverse safety on garage door openers. That won't be easy to install aftermarket as it probably incorporates some sort of amp draw detection on the motoror torque feedback (non-engineer guessing).
Old 11-29-2007, 08:28 PM
sferrall's Avatar
See below
Old 11-29-2007, 08:44 PM
sferrall's Avatar
Actually, I just looked in a 2008 camry brochure and the XLE has the auto up and down, so just go to your toyota dealer and pick up all the parts you need if money is no object.
Old 12-01-2007, 01:55 AM
cowabunga's Avatar
Yep. 08 XLE V6 definitely has auto up/down although only for the drivers window.
Old 02-26-2008, 11:58 PM
4ageBT's Avatar
ORIGINAL: sferrall
Actually, I just looked in a 2008 camry brochure and the XLE has the auto up and down, so just go to your toyota dealer and pick up all the auto parts you need if money is no object.
Yeah, Camry's have that as a standard function for the driver side only. If your doesn't have one then you can have it replaced anytimem its only the switch anyway.
sparky2
01-12-2009 09:01 AM
wlandymore
02-25-2008 12:10 PM
StoreKeeper
11-27-2007 11:32 PM
Quick Reply: 07 Camry Auto Window Down Switch
