07 camry Clacking sound
hello everybody i have a problem with my camry 07 with 64,000 miles, recently starting doing a clacking popping sound when turning left of right. the weird this is it only does it when im backing up and i make a sharp turn. when the car makes a turn on the street i dont hear it anymore is only when backing out. i cant seen to figure out. I already check the VC joint cause that was the most possible reason why, but they look in pretty good shape no leaks no cracking nothing. does anybody else in here might now what could be wrong? suspension maybe ? i dont know.
well if thats the case i dont think is the mount or bearings. because when i bounce the car i dont heard anything. The weird think is like i said it only makes that sound when backing out of a parking space. if i park the card facing forward and i turn to either direction it does not make the sound ??
ok i just had time off to do the test , this is what i found out. i did the tight turn parking lot test and i noticed it only makes the sound when turning the left. it sounds clearly coming from the left cv axel. no matter which way i turn it ,the noise is always coming from the left side . i also remember a guy saying on youtube that when making a turn and you heard the sound turning right it was the left one that was bad, because all the weight of the vehicle is on the opposite side but i did the test in reverse though because otherwise i dont hear anything. what do you think ? im glad is the driver side one because the left side has a bearing right in the middle of the shaft which i heard is a pain to get off lol.
