Sponsored by:
Sponsored by:
1992 4 cylinder am2 fuse keeps blowing
Old 05-05-2011, 11:24 PM
murray.b's Avatar
Default 1992 4 cylinder am2 fuse keeps blowing
car died while driving, turns over great but keeps popping am2 fuse every time I try to start.
Old 05-06-2011, 10:01 AM
AM2 fuse powers the ignitor, coil, injectors, engine and trans ECU, EFI main relay.
A white/red wire.
The is a noise filter (capacitor) behind the air cleaner box, firewall side. Sometimes this filter shorts to ground.
Old 11-01-2011, 09:08 PM
SERRANO239's Avatar
so what would be the solution to this problem!!!
Old 11-02-2011, 03:19 AM
SERRANO239's Avatar
Ok found the ego capacitor it is located inside the distributor on the left handside behind the brass bar and wires.. it is a round small cylinder like object with a brownish wire coming from it...cut that wire....
It should stop the fuse from popping it worked for me....
skenzer
07-13-2013 12:02 PM
heman8400
09-09-2012 10:51 AM
camryvasaq
07-10-2012 07:38 PM
windsail47
10-01-2007 09:46 AM
bst00
02-27-2007 01:33 PM
Quick Reply: 1992 4 cylinder am2 fuse keeps blowing
