1993 Camry 4cy Throttle sticks at 0 (Idle) Position.
Old 02-12-2013, 11:27 AM
umdaman's Avatar
Default 1993 Camry 4cy Throttle sticks at 0 (Idle) Position.
Recently my throttle has been sticking at idle. I have seen this discussed one time before but the image was removed so I have no idea what needs cleaning. I have attached some photos. When turning it, it's the same feeling as if your just broke a small screw loose. Kind of hear that click sound then it moves freely. It doesn't stick all the time. But I would say about 60-75% of the time when driving and going to push the gas peddle again, I feel the resistance.
I recently bought a 2000 Camry 4cyl, which also has the same symptoms as my 1993.
Attached Thumbnails 1993 Camry 4cy Throttle sticks at 0 (Idle) Position.-102_5637.jpg   1993 Camry 4cy Throttle sticks at 0 (Idle) Position.-102_5638.jpg
Old 02-12-2013, 07:34 PM
go-part's Avatar
Former Sponsor
Try cleaning the throttle body itself and see if that helps your problem
http://www.ehow.com/how_5731558_fix-...ota-camry.html
Old 02-24-2013, 09:25 AM
umdaman's Avatar
Thumbs up
I cleaned the throttle body last weekend. It seemed to help a LOT, but it was still sticking a little bit. But as of yesterday it has not been sticking at all anymore. So I'll probably try cleaning it some more when it gets warmer out. There was a lot of black gunk in there thats for sure.
Thanks for the tip.
How to Fix a Sticky Accelerator on a Toyota Camry | eHow.com
ssulaco
09-05-2011 12:15 PM
Mr Rumblur
06-06-2011 10:27 AM
rt07
01-11-2011 10:26 AM
brianjrealtor
06-17-2010 04:58 PM
Quick Reply: 1993 Camry 4cy Throttle sticks at 0 (Idle) Position.
