1993 camry bucking/stumbling
I have a 1993 Camry 3.0 V6 XLE. The car runs great, and still does, but I have encountered a problem I have not come across before. The car has an automatic transmission; The problem I am having is a stumbling, revving of the vehicle at initial acceleration from a stop.. A full description of the problem is when the car is in drive, and the brake is released, the car inches forward typically. But when gas is first given, the car acts as if I am pushing and releasing the gas repeatedly, and the car lurches, bucks, and then settles out after 1500 rpm, then continues as normal. The whole time throttle is kept steady, and at a normal rate.
The problem can be stopped, by giving the car a large amount of throttle (near floored). This problem has also caused the car to stall a few times, but other wise the car idles fine, shifts fine, goes into overdrive, etc.
What is the possible cause(s) of this???
Thank you
Thank you
RE: 1993 camry bucking/stumbling
ORIGINAL: Turkgobbler
Thank you
Thank you
This Is the same thing that I'am having with my 1994 camry. I have changed the feul filter and it did not change my problem. I'm going to next try cleaning my throttle body and parts and my IAC ( idle air control) and see if that my fix the problem. If you have fixed your problem please let me know what you did. Thanks
check your air intake pipe for cracks it could be sucking in too much air i just had to recently fix mine i would go from a stop and the car would just sit at few thousand revs for a sec then take off like usual, shat me off so much,
guarantee if my problem sounds like urs it is that
toyotafan111
07-21-2017 01:20 PM
mh4473
12-26-2007 11:28 PM
1993, 92, 95, acceleration, accelerator, automatic, bucking, camry, idle, problems, stumbling, toyota, tranny, transmission, weezer1974
