Just got 2004 Camry with 100K on it. what maintenance is needed?
Just got a used camry with 100k miles on it. wanted to know the following on what needs to be done at 100k and what
Engine oil - ?
Oil Filter - ?
Transmission oil - ?
Transmission Filter - ?
100k mile maintenance - ?
Tune up - ?
Spanks plugs - ?
thanks
Engine oil - ?
Oil Filter - ?
Tune up - ?
Spanks plugs - ?
thanks
so it's 7 yrs old, only medium mileage. Good.
When I get a used car I do all the fluids*, oil filter, plugs, and inspect the air filter and brakes.
Some shops offer a fresh car general inspection for <$50; might be worth it.
Unless you can find different from contacting the prior owner - assume, at 100K miles, the timing belt needs to be replaced.
When you replace it is your call...
* engine oil, radiator fluid, brake fluid, tranny.
bored7one4
07-26-2012 10:33 AM
