1995 CAMRY 2.2 5FSE O2 Sensor Location - Camry Forums - Toyota Camry Forum
LinkBack Thread Tools Search this Thread
Old 03-25-2011, 07:45 PM
Default 1995 CAMRY 2.2 5FSE O2 Sensor Location
Hi Guys,
Where is the O2 Sensor located on the 1995 Camry.
Its the 4 cylinder 5FSE UK Spec.
I cant see it on the exaust at all.
JOHNNYUK
Old 03-25-2011, 09:54 PM
Not sure on UK models.
There needs to be one before and after the converter. Typically it is right before and right after, perhaps on top of the exhaust pipe.
Old 04-11-2011, 05:07 PM
Default O2 sensor sorted.
Hi Joey P.
I finally got this 1995 CAMRY 2.2 sorted.
There is only 1 sensor in MY UK model.
It was not easy to get at as its right under the engine location,
A local garage fitted it for me £10 so it saved me grovelling under the car.
TOYOTA wanted near GB£130 for there replacement .
I purchased one from...theairflowmetercompany on EBay.
Cost was GB£38 including post costs.
The car now is running very well and yesterday I had a 200 mile motorway journey
to do and had to take care as now the legal limit for roads here were so easy to exceed like I kind of remember .
So my feeling is its been faulty in some respect for some time.
In passing the Haynes Manual states that HEATED SENSORS are NOT
fitted to the 4 cylinder 5FSE motor.
Mine is 4 cylinder and it is fitted originally with a HEATED ONE.
TOYOTAs electrical manual shows a heated one in the circuit diagram.
Again thank you for information you have passed on to me.
I am sure others welcome your input to
Take care
Johnny UK
Old 04-11-2011, 11:08 PM
Thanks for posting back with your findings!
From what I understand US cars of this year did not have heaters.
Thread Thread Starter Forum Replies Last Post
Coolant leak in 2000 5FSE, by timing cover paranoidjack DIY - Do It Yourself 1 03-14-2012 11:10 AM
96 camry 5fse no idle twizzerb General Tech 5 06-23-2010 06:24 PM
1996 2.2 5FSE Camry cooling problem deepcdiver Engine & Internal 1 12-23-2007 10:23 PM
95 camry 5fse no start Rolley Noodles General Tech 1 04-03-2007 04:00 AM
96 Camry LE 4 cyl 5FSE engine won't start icemanbell General Tech 1 01-09-2007 11:30 PM
Tags
08, 1995, 95, camry, camry22, change, code, cylinder, le, o2, oxygen, pictures, replace, replacement, sensor, show, toyota
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
