1995 Toyota Camry ATF Recommendations
Hey all. So I've got a question. Recently my sister purchased a 1995 Toyota Camera, sorry Camry. We'd like to change the ATF on it as it has shown a little bit of browning and what not. I searched around and only found that Dexron 2 or 2D was recommended. I know some of the transmissions on certain cars can be very picky in terms of what you put in them, so I was curious to know if I could put in Dexron 3 or something of that nature in, and if so, what would you guys recommend for this vehicle. Thanks for the input guys, God bless.
-Josh
-Josh
For this car Dexron III is used. III replaced II.
In the past vendors listed the fluid as Dexron III/Mercon. Now vendors also use names such as
Chevron ATF MD3
Valvoline Dex/Merc ATF
Pennzoil Dexron ATF
Carquest Dexron III/Mercon
When looking for fluid read the bottle or info listed for the product. Make sure it is a qualified replacement where Dexron III was specified.
Chevron ATF MD3
Pennzoil Dexron ATF
learn2turn
04-15-2016 12:49 AM
2007xle
10-08-2011 08:21 PM
