1MZ-FE engine has no power
i have a 94 toyota camry v6 le coupe with a 1MZ-FE engine. when i press the accelerator i get barely any power. i can only reach 2200 rpm. the car will only go into drive or park. the engine is getting fuel so i assume its an airflow problem but i am totally lost.
You can rev the engine higher in Park or Neutral?
May still be a fuel issue. A badly plugged fuel filter (rare but happens) or failing fuel pump can cause the engine to rev OK in P or N but barely have enough power to make it over the curb onto the driveway.
namesbs
10-13-2010 10:23 PM
ggcc
04-27-2007 05:15 PM
