2000 camry ce passanger power window stuck in closed position
Old 10-01-2015, 11:48 PM
Alexis Diaz's Avatar
Default 2000 camry ce passanger power window stuck in closed position
The reason I say stuck is because when I changed the window motor it automatically goes to the up position. Okay so I changed the switch on the passenger door that didn't work. I ordered the master switch because the passenger window switch is broken and it just arrived today. I'm installing it tomorrow. If that doesn't work I'm gonna try to change out the harness but If anybody has a better idea. A simple fix let me know please and thank you.
Old 10-02-2015, 01:04 AM
While you have the door apart, check to see what wires are running hot with the ignition on, if any. Also, check the harness between the chassis and the door, make sure the wires are in good condition and not damaged.
Old 10-02-2015, 03:34 PM
All the wires in between the chassis are fine. It ended up being the master switch. I swapped it out. Plugged in the passanger switch and the window rolls up and down. Thanks!
Old 10-05-2015, 12:24 AM
Glad to hear it is fixed and the solution. Thanks for updating us!
2001CamryLe
06-17-2016 02:21 AM
Childeric
05-09-2015 12:02 AM
rt07
01-11-2011 10:26 AM
hayhayday
05-12-2009 10:10 AM
Tommy D
08-05-2008 10:20 AM
Quick Reply: 2000 camry ce passanger power window stuck in closed position
