Sponsored by:
Sponsored by:
2001 Toyota Camry keep blowing the 10A guage fuse when shift into reverse.
Old 07-06-2009, 10:34 AM
moshlub's Avatar
Question 2001 Toyota Camry keep blowing the 10A guage fuse when shift into reverse.
A few week ago my tail light indicator on the dashboard came on when I step on the brake pedal, I check and found one brake light was much dimmer than the other, I but didn't have the time to replace it, so I drove a week without any problem, then yesterday I went to the mall, on my way home I notice that the speedometer, cruise, tach meter quit working, when I got home my battery went dead (1 hr drive). I replaced both of the brake lights, inspected all the wires in the trunk and it appear to be good condition and I replaced the 10A guage fuse, everything seems to be working order except that if I shift to reverse it blew up the fuse immediately, no problem on any other gears. I appreciate any helps or suggestions.
Old 07-06-2009, 08:06 PM
full house's Avatar
you should not drive it after seeing the problem. It would worst the problem... I suggest take to the mechanic and see whats the real score and fix it.
Old 07-10-2009, 12:59 AM
Joel_CA's Avatar
Follow the wiring harness from the trunk lid hinge up into the body of the vehicle and look for any broken wires in the harness. This is a VERY common problem of the wires splitting open. You may need to remove some of the taping around the wire loom protector to get a good look at the wires inside. Pull on them one by one and chances are- you'll find your problem.
JJ
Supra7joey
10-28-2010 10:33 PM
ziddey
04-27-2010 10:12 PM
blong401
03-18-2008 05:17 PM
azazel_18_2
04-22-2007 05:42 AM
bst00
02-27-2007 01:33 PM
Quick Reply: 2001 Toyota Camry keep blowing the 10A guage fuse when shift into reverse.
