Sponsored by:
Sponsored by:
2002 4cyl Camry P0420 Code HELP?
Old 07-30-2010, 02:38 PM
calderondean's Avatar
Default 2002 4cyl Camry P0420 Code HELP?
I got a P0420 code from my check engine light could has anyone fixed this problem before?
Thanks Dean
Old 07-30-2010, 11:14 PM
TSB EG024-04, July 1, 2004
Title:
M.I.L. “ON” DTC P0420 [Note: M.I.L. = Malfunction Indicator Lamp = Check engne light]
Models:
‘02 – ‘04 Camry (2AZ-FE) (Non PZEV)
Some 2002 - 2004 model year Camry vehicles equipped with the 4 cylinder (2AZ--FE) engine may exhibit a M.I.L. “ON” condition with Diagnostic Trouble Code (DTC) P0420 (Catalyst System Efficiency Below Threshold, Bank 1) in the Engine Control Module (ECM) (SAE term: Powertrain Control Module/PCM). The ECM (PCM) logic has been modified and a redesigned catalyst has been provided.
MODEL Camry (2AZ-FE)
PLANT / PRODUCTION CHANGE EFFECTIVE VIN
TMM Kentucky Line 1: 4T1BE3#K#4U323000
TMM Kentucky Line 2: 4T1BE3#K#4U869000
Tsutsumi Japan: JTDBE3#K#40283686
The repair procedure in this TSB is similar to TSB No. EG013-04 “Excessive Sulfur Dioxide Odor.” The recalibration of the ECM (PCM) should only be performed ONCE.
Procedures:
Recalibrate Engine ECM (PCM)
R & R Catalytic Converter Assembly
All 2002 - 2004 model year vehicles equipped with manual transmissions require replacement of the catalytic converter assembly only.
Applicable Warranty*:
This repair is covered under the Toyota Specified Major Emission Control Component Warranty. This warranty is in effect for 96 months or 80,000 miles, whichever occurs first, from the vehicle’s in-service date.
* Warranty application is limited to correction of a problem based upon a customer’s specific complaint
I hope this can help other people who run into this problem: Dean
Old 07-31-2010, 10:26 AM
Check the emissions warranty paper work that cam with the car. The EPA also mandates an extended warranty on converters for cars (might be the same length as the Toyota extended warranty).
Old 07-31-2010, 01:39 PM
8/80 is the emissions warranty and the car has 117,000miles already
Old 07-31-2010, 09:53 PM
Just for your own interest you might check with a Toyota dealer to determine if the TSB was done on this car.
natemoore
07-07-2013 08:21 PM
bassmaster
02-21-2013 08:37 PM
ToddS
02-29-2012 12:59 PM
don smet
03-16-2011 06:21 AM
richone71
11-14-2008 07:00 PM
Quick Reply: 2002 4cyl Camry P0420 Code HELP?
