2002 Camry LE Need help finding Bank 1 Sensor 1 (Air/Fuel Sensor) Fault code : P1135 - Camry Forums - Toyota Camry Forum
Thread Tools Search this Thread
Old 01-25-2016, 05:34 PM
Default 2002 Camry LE Need help finding Bank 1 Sensor 1 (Air/Fuel Sensor) Fault code : P1135
Hi, I have a 2002 Toyota Camry LE V6 which started to display a check engine light today. In checking the fault code, it shows up as P1135.
Air fuel ratio sensor - heater circuit
For the location it seems to be Bank 1 Sensor 1. The problem is that it is hard to find any info on where that corresponds to the engine. From what I know, there is 1 sensor on the front of the engine, and one on the back, but the bank 1 sensor 1 info is not very descriptive in figuring out which sensor to replace.
P1135 DTC: Camshaft position (CMP) actuator, intake, Bank 2 (trouble code is at the bottom of the page)
http://i.imgur.com/Loo9z6L.png
In looking up compatible parts from Denso, I get 2 results
Denso 234-9047
Denso 234-9042
Overall, I am trying to figure out which sensor I have to replace.
Old 01-25-2016, 10:34 PM
This may sound different but I had some PO171 AND PO174 air fuel codes I could not get rid of for a long time. Long story short wound up cleaning air intake. Problem solved. There is a special spray. Check oreillys or other stores. Google how to clean depending if you have automatic or manual butterfly. My butterfly was filthy and not operating correctly.
Old 01-26-2016, 11:59 AM
Bank 1 is the rear cylinder bank. Sensor 1 is the first sensor on the exhaust system coming off that head. Its location is before the emissions converter.
You want upstream (before converter), rear (rear cylinder bank) which is 234-9047.
Shop the internet for the lowest prices.
Old 01-27-2016, 02:59 AM
Thanks, I will work on getting that, and see if it can be accessed without having to go under the car.
Old 01-31-2016, 12:33 AM
More strange issues. Due to all of the snow and the location of the sensor, I am not able to get to it, so I went to a mechanic shop to get an estimate on how much they would charge.
After they used their OBDII tool to pull error codes, I suddenly got 2 additional warning lights
VSC and TRAC OFF
The button corresponding to the traction control does not respond, and those lights do not produce any additional error codes.
Old 01-31-2016, 06:00 PM
If check light is on, VSC and TRAC are programmed to turn off.
Fix the error code problems and when the check light turns off, so will the other lights.
Old 02-02-2016, 01:46 PM
Managed to get everything fixed. The VSC and trac off was caused by a C1336 error.
I had to short pins 4 and 14 on the car to reset it.
Not sure what caused it.
Old 02-03-2016, 12:09 PM
Yaw rate accelerator calibration.
If the two lights came on after checking codes, it happens some readers are incompatible and will this problem.
Thread Thread Starter Forum Replies Last Post
2009 Camry v6 need help id bank 2, sensor 2 Lurch63 Headers, Intake, & Exhaust 1 11-16-2015 01:07 PM
Help in Removing A/F Bank 1 Sensor 1 philipstoddard General Tech 6 04-23-2012 09:02 PM
P1135 Code 2002 Camry SE V6 francescotedesco DIY - Do It Yourself 1 08-18-2011 10:47 AM
p1135 Code and Heat Fuel Economy Problems Related? SaganGathering General Tech 0 05-29-2009 03:43 PM
p1135 Fuel/Air sensor, what part to buy RugerRedhawk ECU & Electronics 1 05-08-2008 11:00 AM
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
