2003 Camry XLE No Heat
Old 02-25-2017, 10:28 PM
Doc's Avatar
Doc
Doc is offline
Default 2003 Camry XLE No Heat
All of a sudden, my 03 Camry XLE 4 cyl automatic isn't putting out any heat. Car is meticulously maintained and have never had any issues in 158k miles-ever. When you increase the temp from 65* to 85* (Hot) nothing happens..temp does not change a bit coming out of the vents. Running temp at the radiator is hot as are the gauges and the 2 hoses to the heater core. I've flushed the coolant every 15-20k miles faithfully and its still very clean & fresh. I believe the problem is with the doors under the dash from the heater plenum? Can anyone expand on this and offer up a few troubleshooting tips? Thanks in advance-this seems like a great forum for all things Camry!
Old 02-26-2017, 12:26 AM
dirty hands's Avatar
if not a fuse problem
could be directional flaps or air mix module behind the dash
may be motorized or vacuum operated actuators
Old 02-26-2017, 09:43 AM
Doc's Avatar
Doc
Doc is offline
Oh man, I didn't even figure in the 'blown fuse' equation! <smacks head> Thanks for the wake-up on that...I'll go out & check to see if the fuse is good (which I SHOULD have done first!) I'll be sure & post my findings, and again-thank you!
Old 02-26-2017, 10:25 AM
Actuator is electric.
You should be able to watch door actuator movement. Location is on passengers side of the climate control unit under the dash.
Old 02-27-2017, 12:29 PM
Doc's Avatar
Doc
Doc is offline
OK, here's a quick follow-up.....I checked the fuses-all are good. Figured I'd wait a day or so and get into tackling this problem. Get into the car this morning, it's about 29*F out, and started it. The panel was set for 77*, like it had been all last week. Well, now there's heat coming from it like this had never happened. I will note this, and I think this might be at play here- like I said, it was 29*F this morning. All last week (when the problem occurred) we didn't get below 45*. I'm wondering if this outside ambient warm temp had something to do with this? Just throwing this out there.....
Old 12-02-2021, 10:07 PM
Sully's Avatar
Does the air blend actuator control heat and cold air?
Old 12-03-2021, 12:01 PM
Yes, the door blends the hot and cold air. There is no longer a coolant temp valve as on the older cars.
Florida Guy
01-07-2024 10:48 PM
Tony Back
09-03-2014 12:25 AM
motmcd
07-08-2014 04:51 AM
billt9666
05-16-2014 09:16 PM
Jdale
11-14-2006 03:08 PM
Quick Reply: 2003 Camry XLE No Heat
