2007 Camry Engine Noise
I seem to be getting a grinding type of noise coming from the belt area in the engine. Maybe the wheel pulleys need to be oiled? Or need to change the belt/pulley? Its a 2007 Camry LE with about 92K miles on it.
One or more of the bearings could be bad. If you take some belt dressing or some wd40 or some kind of lubricant and spray just a little bit on the bearings one at a time while the car is running and it stops then its probably the bearing for that pulley. There may be an easier way to test but that's how I've always done it and it's always worked out great for me.
How hard is the job?
Let look once again to make sure which one it is. Also I have the 4 cylinder.
