2007 Camry Engine Noise
Old 07-29-2014, 07:06 AM
regdawg's Avatar
Default 2007 Camry Engine Noise
I seem to be getting a grinding type of noise coming from the belt area in the engine. Maybe the wheel pulleys need to be oiled? Or need to change the belt/pulley? Its a 2007 Camry LE with about 92K miles on it.
Old 07-29-2014, 09:41 AM
Toyotaguy's Avatar
One or more of the bearings could be bad. If you take some belt dressing or some wd40 or some kind of lubricant and spray just a little bit on the bearings one at a time while the car is running and it stops then its probably the bearing for that pulley. There may be an easier way to test but that's how I've always done it and it's always worked out great for me.
Old 07-29-2014, 09:58 AM
regdawg's Avatar
If the WD40 makes the noise go away, do the bearings need to be changed or the lubrication is the fix?
Old 07-29-2014, 10:18 AM
Toyotaguy's Avatar
No the pulley would need to be changed. The lubrication is just to see if the bearing is the problem.
Old 07-29-2014, 10:20 AM
Toyotaguy's Avatar
but while you're at it, you should check the belt for cracks or damage and change it as well while you're at it if need be. If you find out what it is let me know and I can get you a good price on parts.
Old 07-29-2014, 10:23 AM
Toyotaguy's Avatar
and don't be trigger happy with the lubricant. You only need a little bit
Old 07-30-2014, 10:24 PM
regdawg's Avatar
Looks like the pulley needs replacing. Might as well change the belt to.
How hard is the job?
Old 07-30-2014, 11:47 PM
Which pulley? Yeah, I bet the belt is due for a change as your car is coming up in miles.
Do you have the V6 or 4 cylinder?
Old 07-31-2014, 06:48 AM
regdawg's Avatar
Let look once again to make sure which one it is. Also I have the 4 cylinder.
Old 07-31-2014, 03:45 PM
Toyotaguy's Avatar
Did the lubricant trick work for you?
96camman
01-16-2011 04:32 PM
buch75
05-28-2010 01:24 PM
buch75
11-09-2009 11:48 PM
aolsen
11-14-2008 06:08 AM
camry07
06-08-2008 02:40 PM
Quick Reply: 2007 Camry Engine Noise
