1997 camry no dash lights a/c fan no windows
Old 12-27-2015, 07:50 PM
Lieder's Avatar
Default 1997 camry no dash lights a/c fan no windows
Hey I have just brought a 1997 camry well driving it home I noticed all the dash lights has turned off as well as the radiator fan the windows had also lost power any help regarding this would be greatly appreciated thankyou
Old 12-28-2015, 11:26 AM
Dash lights as in climate system, glove box, shift lever, etc to?
Do the tail lights and door locks work?
Do the fans cycle on and off when the A/C is turned on?
Old 12-28-2015, 05:46 PM
Lieder's Avatar
No dash lights glove box light doesn't work don't know if it ever did no lights on shift lever the tail lights as well as the front lights blink and then turn off and the fan turns on with ac also the electric windows have stopped working thanks for the reply
Old 12-29-2015, 08:27 PM
If front lights are blinking when AC or windows are working there may be a problem with the wiring, battery, connections at the battery, or alternator output.
The issue may be the power to the lights and other systems is weak. The extra load of the AC or windows now causes a further drop in voltage.
Check the battery for full charge, alt is charging OR, battery cables and connections to battery are OK, battery ground cable connection.
Old 12-29-2015, 11:58 PM
Lieder's Avatar
Tried a new battery checked conections alternator is good still no dash lights and the lights flash brightly once then turn off and stop working completely car still turns over and starts normally
Old 12-30-2015, 02:37 PM
Check for power window operation at any window. If no power windows check Door, Gauge and Power fuses.
If taillight work the for dash light issue make sure the dimmer is turned up and check Panel fuse.
lemmon_water
07-01-2015 05:18 AM
ati2d
03-29-2012 10:23 AM
jetfire
07-03-2009 02:34 AM
Mark61
05-18-2009 08:34 PM
jeannekrieg
03-07-2006 07:19 PM
Quick Reply: 1997 camry no dash lights a/c fan no windows
