Sponsored by:
Sponsored by:
87 Camry check engine light On question about what makes light come on?
Old 03-29-2010, 11:35 PM
hardyrxp's Avatar
Default 87 Camry check engine light On question about what makes light come on?
Hello,
I have a 87 Camry 2.0 5 speed with 169k on it. The car has a check engine light that comes on after a few minutes of driving it seems to be on a timer as it comes on after a couple of minutes not right away. I need some help here as this is a older car. What makes/triggers the check engine light to come on in a 87 Camry and what can I do to find out what is the problem? Also I might add I saw a diagnosis plug near the battery under the hood I was wondering where can I get a device that will plug in there and let me know what the light means? I guess I should 1st ask do they make a device like that for such a older diagnosis system on that car?
Also is there a code system on that car like on my Honda where I can find out what that engine light means? Thanks so much for the help as I have no clue what to do 1st here or how to find out what is going on.
Dave
Old 04-05-2010, 12:31 PM
k0ota_banGq's Avatar
you should just get it checked with a diagnosis tool, because a check engine light can come on for numerous reasons.
Old 04-06-2010, 09:09 AM
The Autozone websites vehicle repair guide section may have the procedure to check the trouble codes using the computer built-in readout system. This uses the CEL to flash out any stored codes.
sconley
03-02-2012 09:33 AM
hardyrxp
03-31-2010 02:10 AM
the.stick
01-16-2010 10:48 AM
burkej62
01-29-2008 10:06 PM
jnthn
04-23-2007 04:28 AM
Quick Reply: 87 Camry check engine light On question about what makes light come on?
