92 Camry knocking noise from front passenger side
Old 04-22-2012, 06:01 PM
TheFreshman's Avatar
Default 92 Camry knocking noise from front passenger side
I drive a '92 Camry, 180k miles, and recently noticed a knocking noise coming from the front passenger side of the vehicle. The knocking increases and decreases in frequency in direct correlation to how fast I'm driving. I checked the tire for any objects stuck in a tread: nothing. The noise is not always present. It knocks more often when I'm turning the car, although it still happens sporadically when driving straight.
I'm not too experienced with cars; initially thought it was a CV joint, but then read this thread (https://www.camryforums.com/forum/ge...end-noise-233/) which led me to believe it may be a bad sway bar end link/bushing.
Hoping it's a relatively simple fix. I'm trying to avoid replacing something that doesn't need to be replaced.
If it's the sway bar end link and bushing, can I just replace the one or do I need to do both?
Appreciate any help.
Old 04-22-2012, 09:03 PM
full house's Avatar
I think its just the sitters, maybe they are loosing the grip.
Old 04-22-2012, 09:10 PM
Make 90 and 180 degree turns L and R at low speeds on flat surfaces (no bumps or potholes). If the knocking increases when turning one direction and decreases or stays the same turning the other check the CV joint.
Shawn98408
10-18-2010 08:58 PM
mheredia2930
06-03-2009 11:43 AM
ron111
03-26-2008 09:36 PM
beltzie55
08-06-2007 06:39 AM
madmax3040
05-14-2007 01:06 PM
Quick Reply: 92 Camry knocking noise from front passenger side
