Sponsored by:
Sponsored by:
93 camry speedometer and tachometer not working correctly
Old 06-22-2009, 01:39 AM
superhighguy's Avatar
Question 93 camry speedometer and tachometer not working correctly
I recently changed my thermostat, temperature switch and battery in my 93 camry 4 cyl, but when i took my car around the block to test my work, my speedometer and tachometer are reading incredibly low. Is this something i can fix on my own?
Old 06-22-2009, 06:45 AM
pedro's Avatar
Not sure how to help. The speedo takes signals off the vehicle speed sensor (VSS) on the transmission while I believe the tach uses the ignition system through the ECM. Is the engine running ok and is the trans shifting alright?
Old 06-22-2009, 07:46 AM
Yeah, everything seems to be working alright.
Old 07-01-2009, 08:40 PM
HI85WH1's Avatar
This sounds exactly like my 1993 Wagon...
Odometer and Trip meter work fine (used the mile markers on the freeway)
But the tachometer never goes over 500rpm and the speedometer read 40 mph while passing traffic... (I slowed to 30 to not get a ticket)
GM_Firebird1967
10-19-2017 02:41 PM
marklee57
02-11-2014 10:00 AM
gilhouley
03-29-2012 03:41 AM
camryhelp
04-04-2011 05:23 PM
beadingmom17
03-18-2009 10:30 AM
Quick Reply: 93 camry speedometer and tachometer not working correctly
