Go Back   Camry Forums - Toyota Camry Enthusiast Forum > General Toyota Camry Forums > General Tech
Sign in using an external account
Register Forgot Password?
Search
submit to reddit
LinkBack Thread Tools Search this Thread
Old 05-23-2008, 07:14 PM
Default 94 le locks
Some kid kicked my driver side door and now the lock is broke. Specificaly i can't unlock the driver door. Insurance decided it wasn't going to cover it so i have the car half open at the moment trying to fix it. As i can't open the door, i am unable to take the inside paneling off all-the-way but i have managed to peel it back to a point in which i can access the inside of the door. I see all these rods going through my door, and i have identified most of them (inside door handle, key hole, etc.). Is there a certain lever or something i can hit that will act as a sort of master release now that i am in the car? Also, if i had a digram of the lock system it would be much appreciated. If there is no master realeas, what do i need to do (as far as moving the rods around) in order to unlock it, assuming it can still be unlocked.
Thanks
~fritz
This ad is not displayed to registered members.
Register your free account today and become a member on Camryforums!
Old 05-24-2008, 12:15 AM
Default RE: 94 le locks
You can't pull up on the locking ****, autolock does not work, door handle does not move, key does not turn?
__________________
Joey P
Old 05-26-2008, 07:24 AM
i can lift the handle to the door, both inside and out. But the auto locks don't affect that door (they do work on all the other locks) the indicator next to the handle on the interior, that you can flip to unlock it, doesn't turn (well it didn't. ive got the door half apart at this point and that has been disconnected) and the key will not turn in the lock. I can see down in their, and it looks like there is a "hook" of metal (a sheet, about 1/8" thick) that has been bent. IDK if this is part of the lock mechanism or if it is for holding the mechanism to the door...
is their a diagram out there that will tell me what everything does and the names so that i can troubleshoot it?
Old 05-26-2008, 11:48 AM
http://camrystuff.com/manuals/Gen3/be.pdf
See page BE-90
__________________
95 2.2L LE Wagon Auto Trans 150,000 miles.
Old 05-26-2008, 01:11 PM
no i need a diagram of the actual lock and motor, not of the door
Old 05-27-2008, 01:39 PM
Don't think you are going to find a closeup diagram of the lock itself but this may help.
http://z.about.com/d/autorepair/1/0/k/r/00000100.gif
__________________
Joey P
Old 05-27-2008, 04:53 PM
We got her open today...by a combination of brute force and ppure luck actualy...oh and a welding rod. Turns out a spring down inside it was broken and therefore some part of the lock wasn't sitting in the right position. We took her out and found that was it, so were going tomorow to get the spring andthe handle my dad snapped off when we were taking it out. second handle hes broken off a toyota this year, must have a vendetta...
turns out that i couldn't operate the locks by key because a tumbler isn't moving...my key might be wrong. We'll see 2moro
Old 05-27-2008, 08:44 PM
Send a message via AIM to 94camguy
Didnt you say a spring was screwed up? that could be why the tumbler wasnt moving, I had the same issue with my old buick skylark, I took out the locking mechanism itself and my father in law opened it up and straightened out whatever was not in place. The tumbler was stuck in mine as well.
Not necessarily the answer, but a hopeful maybe.
__________________
Toyota: Moving forward (even when you dont want to)
submit to reddit
Tags
1994, 94, camry, camrydoor, diagram, door, handles, inside, lock, mechanism, open, stuck, toyota, tumbler, work
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
