95 Camry problem
95 Camry problem
Hi
I have a 1995 Camry 254000 miles V6 The problem is that the other day the electronics on the windows and door locks stopped working I have checked all the fuses I think There is no charge going to the door panel where the switches are by the driver so it must be a fuse or something I am needing advice on where I can find the fuse for the doors and windows Any idea? thanks in advance Rolef
Hi.. No.. nothing works as there is no power going to them.. There is no power in the switch on the console at the drivers side so it must be a Fuse .... I am trying to find where the fuse is for the Power to the door Locks and Power windows thanks
You checked the Gauge and Power fuses?
If you have power seats or moon roof do these work?
When the ign switch is in a position that normally would allow windows to be operated the power main relay is turned on (located in a relay panel on the left side of instrument panel behind ash tray).
Determine if the relay is turning on.
Power then runs to the drivers door.
Often the wiring between the door and chassis breaks due to flexing with door usage.
The power window switch should have power at the Blue wires, when the relay is on. If not there may be a wiring problem.
Found a solution!!!
I had the same problem and I looked EVERYWHERE for an answer. There's another fuse panel hidden next to the steering column on the left. You gotta unbolt the panel under there and pull it off, and you'll see a reddish brown box of relays (I think that's what it is, I didn't open it) and next to the box are some square fuses. I saw the problem instantly, and here's the link for how I found it. It's another forum, and thankfully the guy who fixed his posted pics! I registered here just to pass along the info, so if you want to you can find someone else with this problem and pass it along. HTH!!!
Power Window Fuse - Toyota Nation Forum : Toyota Car and Truck Forums
