96 Camry oil leak
Old 09-01-2006, 06:26 PM
woody1953's Avatar
Default 96 Camry oil leak
Ok, have an oil leak, i've had the car for more than 3 weeks, gotta get it out, lost my a$$ on this job. Its a camry '96, with a 5s-fe. Its leaking oil through the "air gap" behind the oil pump side cover, have put 2 gaskets and an o-ring(for the pump) o-ring was bad, also replace front seal located in the oil pump housing and a leaking cam gear seal. and it's still leaking a drop of motor oil every second after it runs for a few seconds, and its coming from the spot marked with the yellow circle. Pretty sure this is just above where the left side of the gasket ends. that "air gap" area where there shouldnt be any oil, i always find some when I take the cover off.
[IMG][/ihttp://www.toyotanation.com/forum/showthread.php?p=1399791#post1399791mage]
[IMG]local://upfiles/1220/5C72B14358304F9282A5FD15ECBDCAD6.jpg[/IMG]
[IMG]local://upfiles/1220/8F176EDDEAC841C5810457FD864D29F9.jpg[/IMG]
Old 09-05-2006, 05:23 PM
lavalleemike's Avatar
Default RE: 96 Camry oil leak
Ok this is an odd one. It looks to me like the gasket for the pump probaby isn't sitting right one the engine if i were you i would pull the oil pump off and clean where the gasket sits real real good and then add a little bit of a silicone sealer. to seal up the spot where its coming from.
Old 09-11-2006, 05:23 PM
woody1953's Avatar
Read your reply lavalleemike. Hear is everything I've done so far:
Replaced all seals and gaskets including the following:
1. Camshaft seal
2. Crankshaft seal
3. Oil pump seal
4. Oil pump O-Ring gasket
5. Oil pump gasket (between housing and block using gasket and Toyota sealant)
Car still leaks in the same spot. The only thing left is to replace the oil pump itself or there is a crack or hole in the block. THIS IS SOOOOO FRUSTRATING!!!
Old 09-12-2006, 03:40 AM
Joel_CA's Avatar
Add some dye to the engine oil and clean off the area in question with parts wash spray. Take the timing covers off, reinstall the harmonic balancer and run the engine. As soon as it starts to leak stop the engine and inspect it closely. Hopefully, the source of the leak will be more obvious with the dye. You can go as far as sprinking baby powder over the area so i can at least get a visual once the wet spot starts. Since you've gone as far as removing the oil pump housing, you should've just replaced it since you went through all that trouble anyway. At that point, you would have at least eliminated that as a possibility. Good Luck!
J
Old 09-13-2006, 10:00 PM
woody1953's Avatar
Hey Joel,
Thanks so much for the dye idea. What type of dye should I use? Where can I purchase it? How much do I use? Sorry about all of the questions.
Old 09-14-2006, 01:09 AM
Joel_CA's Avatar
I'm not sure how much it will run you as our dealership has it's own kit. The dye WILL require a special blue lamp as well as yellow goggles in order to see the dye will. If it is coming through the block, you should be able to see the crack as it will shine in bright yellow (with the lamp and goggles). You can even spray the leaky are with parts wash and watch it come out again and again as it continues to leak. Good Luck!
Joel, CA
Old 09-14-2006, 02:57 PM
We have the kit at my toyota dealership to but, i dont think we sell it try a parts store. i know the kit we use comes from snap on. You could try the baby powder idea its cheaper and works about the same
Old 09-15-2006, 09:30 PM
woody1953's Avatar
Hey everyone. I replaced the oil pump and that fixed the leak. The old one must have had a hole or was warped. Thanks for all your help.
Old 03-19-2011, 06:24 PM
scottnsage's Avatar
never mind
Old 03-19-2011, 11:32 PM
scottnsage's Avatar
Default 1996 toyota oil leak
shop cost for repairs 1996 toyota camry 2.2l oil pump seal
Quick Reply: 96 Camry oil leak
