'97 hard to start when it's cold - Camry Forums - Toyota Camry Forum
Thread Tools Search this Thread
Old 08-31-2012, 07:03 PM
Question '97 hard to start when it's cold
Hey everyone, I've got a '97 camry 2.2 5sfe, which I handed down to my son a few years back...last week he was driving it when the water pump seized, shredding the timing belt and blew a head gasket. Dad to the rescue, I surfaced the head replaced gaskets,plugs,wires...etc. I get it back together and now I'm having starting problems. If I crank it over for 15-20 seconds and feather the throttle, it barely runs, until it warms up to running temp. Once its warm, starts right up and runs like a champ (I still haven't driven it, it's on jackstands til I figure this out) 1st thought it was timing...not it, then vacuum leak...found 2 hoses, replaced 'em..not it! Can somebody offer me some insight, I'm baffled. Thanks, Scott
Old 09-01-2012, 10:25 AM
Might check over the IAC valve, it's electrical connections and coolant plumbing. The valve is responsible for metering bypass engine intake air around the throttle plate.
The valve response to signals from the engine computer and coolant temp.
Make sure the hose to the MAP sensor is OK and connected to the right port.
Old 09-02-2012, 09:55 PM
yep, most of the time it's the IAC... problem like that starts on the IAC.
Thread Thread Starter Forum Replies Last Post
Hard cold start bcravens General Tech 13 08-13-2015 12:16 AM
camry a/c cold and not cold foxyroxy111298 Engine & Internal 3 04-19-2012 10:15 PM
2008 Camry hard cold start charlieqf General Tech 0 12-19-2010 07:23 PM
1997 camry hard to start camaro1185 ECU & Electronics 2 05-14-2008 07:35 PM
'93 V6 Camry hard to start when cold briansturgeon General Tech 0 10-26-2006 09:44 AM
Tags
2000, 22, 5sfe, 97, camry, cold, forums, hard, iac, start, starting, starts, toyota
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
