'98 camry 5-speed squeaky clutch
My clutch squeaks. i have put grease in the fitting on the clutch and strayed wd40 around that area. It stopped for a while and started squeaking again. I know there arent a lot of stick-shift camrys, but can someone give me some insight to this problem.
RE: '98 camry 5-speed squeaky clutch
Squeak as in when you push on the clutch pedal?
WD-40 is great as a short term lube but bad for long term. It is mostly kerosene or something like this. Try LPS3 or a spray on lithium grease.
Where is the noise, outside or inside the bell housing.
