Brake fluid flush - Camry Forums - Toyota Camry Forum
Thread Tools Search this Thread
Old 07-23-2009, 06:06 AM
Default Brake fluid flush
How often, (if at all), should the Brake Fluid be replaced on a 2005 Camry. MAVIS suggests every 30,000 miles @ $79.95
Old 07-23-2009, 02:59 PM
Depends on where you live. Here in NC the humidity is so bad I do mine once per year. Brake fluid absorbs water, unless you have the new silicone, then maybe the 30K will be ok. When in doubt flush it, it is pretty cheap insurance.
Old 07-23-2009, 09:34 PM
Talking
Most people drive their cars for years and thousands of miles without ever doing anything but adding a little when brake work is done and the lines have to be bled. Under normal driving conditions no one will ever notice the difference in braking. I would venture to say that only a few manufacturers even suggest replacing the fluid and most of us on these forums probably can't afford those cars. My question to those who suggest that it is ABSOLUTELY NECESSARY is simply; How does it benefit you?
Most of us will trade, sell, wear out engines and transmissions, or wreck the vehicle before old brake fluid will ever cause a problem.
That said I like to siphon out the resivoir and refill every year or so. When I do any brake work requiring bleeding I will give the pedal a couple extra pumps to clear the lines. Those of us on these forums like to tinker with and pamper our cars and often do stuff that will not make any difference in the long run. But it does make us happy today and that means a lot. I try not to confuse things I must do to my cars and things I like to do to my cars. Sometimes that distinction gets fuzzy. I say change it every day if it makes you happy, but you probably never really have to.
Old 07-24-2009, 05:58 AM
Quote:
Originally Posted by flyerI View Post
Those of us on these forums like to tinker with and pamper our cars and often do stuff that will not make any difference in the long run. I say change it every day if it makes you happy, but you probably never really have to.
The discoloration in brake fluid is water. Water boils at 212F at sea level and lower at elevation. When you need your brakes, like long down hills or emergency braking, boiling water in the brake system will not help you stop, nor will water extend the life of components.
Manufacturers don't tell you to do a lot of things, that doesn't make doing them useless or that they won't reduce wear and tear and early breakage. When
Americans thought at turning over their cars every 2-3 years and accumulating unsustainable debt was the thing to do then maintenance could always be left to the next owner, but now that vehicles may be driven longer then YOU are the next owner.
Thread Thread Starter Forum Replies Last Post
When to change brake fluid? Icebeam47 General Tech 1 09-09-2012 05:12 PM
Putting Brake Fluid In The Engine Oil!? 94Owner General Tech 1 06-12-2012 03:08 PM
Transmission Flush imranul General Tech 18 11-10-2011 03:27 PM
Fuel tank flush? thecaveboy General Tech 5 02-03-2009 11:48 PM
Automatic Transmission Fluid instead of Power Steering Fluid?? melahi General Tech 6 06-20-2008 09:49 AM
Tags
2005, 2007, 2008, 95, brake, break, camary, camry, change, fluid, flush, miles, recommended, reducing, system, toyota
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
