Sponsored by:
Sponsored by:
Brake and Reverse lights do not work appropriately
Old 03-08-2012, 07:29 PM
Guyii's Avatar
Default Brake and Reverse lights do not work appropriately
My Brake lights do not turn on when I press the brake pedal but all the fuses are good and and the light bulbs in working condition. My Reverse lights do not Turn on either. Again bulbs are good and fuses are good but I did have to replace the Lamp failure module several times. Can somebody help me!?
Old 03-08-2012, 09:12 PM
Determine if the brake lights are getting 12V power when the brake pedal is pushed and the socket has a good ground wire circuit.
For the reverse lights check for damage in the trunk where the wire harness transitions from the chassis to the trunk lid.
Old 03-14-2012, 10:59 PM
Guyii's Avatar
Okay so I mistake. The brakes do work but the reverse lights do not. I have checked the wiring on the trunk and they all are fine. bulbs and fuses are fine but still no power to the sockets. and sorry for the late response. I came down with the flu
Old 03-15-2012, 03:28 AM
full house's Avatar
break is very important, maybe they are not properly connected to the break double check it.
Old 03-15-2012, 07:08 AM
Guyii's Avatar
The brake is fine. The reverse lights however aren't coming on. Fuses are fine, along with the wiring to the sockets but no light.
Old 03-15-2012, 10:10 AM
Year of car, transmission type, engine model?
Old 03-15-2012, 10:07 PM
Guyii's Avatar
1988 Camry v6. Had the tranny replaced so that could be the root to the problem
Guyii's Avatar
They only came in Auto with overdrive
Old 03-16-2012, 09:23 AM
Look in the trans case for a switch like the ones in the link below:
Toyota Camry Back Up Light Switch - Free Shipping - Standard, Beck Arnley, AC Delco
Make sure the switch is wired up.
Power wire might be red/blue. Wire to lights red/black.
Old 03-16-2012, 09:44 AM
Guyii's Avatar
Inside the case I probably would never bother touching
Quick Reply: Brake and Reverse lights do not work appropriately
