Camry 2000 4 cly Pedal Sticks.
Old 04-24-2008, 08:05 PM
mango02's Avatar
Default Camry 2000 4 cly Pedal Sticks.
The gas pedal sticks at red lights, acts like it has a detent. Checked all cables all look good, lubed every thing I could and it still acts up, checked pedal.
Old 04-25-2008, 01:26 PM
Default RE: Camry 2000 4 cly Pedal Sticks.
Check the action on the throttle body plate, should be smooth without sticking. You can rotate it using the pulley.
If the car has cruise control, the throttle cable may be routed to the the cruise control box first, then another cable goes to the throttle. There might be an issue here.
Old 04-26-2008, 09:01 AM
mango02's Avatar
I took the cover off from the Cruise Control checked the cable run from Fire wall to Throttle Body NOTHING. I tried to lube everything I could. When I operate it by hand it works fine. It only sticks when you first push on Pedal.It makes drivingthe car a pain in the @$$.
Old 04-26-2008, 11:08 AM
Remove the cable and check the throttle plate for sticking. The throttle should also have an unloader mechanism, a dashpot that bumps the throttle arm up a little to prevent sticking at engine idle Have someone operate the throttle pedal while you watch the throttle pulley and cable action. Remove the throttle body air intake hose and check for a build up of grim.
Old 04-26-2008, 03:05 PM
mango02's Avatar
I think you are right it has to be in the throttle plate got some throttle body cleaner first chance I get I will spray it. Cables and pulleysare good.
Old 04-27-2008, 08:37 PM
mango02's Avatar
toyomoho you are right it was a GUMMED up throttle plate. Sprayed it and like magic no more sticking.
Old 04-27-2008, 09:27 PM
94camguy's Avatar
An extra added bonus, at least it was with how bad my throttlebody and iac valve was.. i got an extra kick after cleaning the body and iac.
dividingbyzero
05-08-2015 09:10 AM
umdaman
02-24-2013 09:25 AM
camdamry
04-11-2008 09:57 AM
JanSport40
03-06-2007 03:15 PM
christyj2
11-16-2006 11:02 PM
Quick Reply: Camry 2000 4 cly Pedal Sticks.
