Old 08-28-2015, 11:36 AM
How-Tos on this Topic
Browse all: Wheels and Tires
Print Wikipost
Car Sat fro 3 1/2 years What do i Do??
Old 07-04-2007, 08:22 PM
sweetlike's Avatar
Default Car Sat fro 3 1/2 years What do i Do??
I have a 89 camry 4 wd has been sitting for over 3 and a half yeasr i want to put i t back on the rd what are some thing i need to have done will even still work??
Old 07-04-2007, 08:45 PM
OnE_To_HatE's Avatar
Default RE: Car Sat fro 3 1/2 years What do i Do??
yepp! it should work. Just get on maintinance ASAP! BELTS and HOSES as well as FLUIDS. 4WD!!! lucky-
Old 07-05-2007, 07:59 AM
pedro's Avatar
Just do the usual. Change fluids, check belts, hoses, charge battery (maybe even new one).
Your biggest problem might be the quality of the gas in the entire fuel system. If you can I would have a garage drain the gas tank so the gas can be disposed of properly. I would then add something like Chemtool B12 to a couple of new tanks of gas to help clean out any residue.
Before starting the car I would also remove the plugs and spray some WD-40 or like down into the chambers. Rust may have formed on the piston rings and cylinder walls so having some instant lubrication will help protect them until the oil gets flowing.
Old 07-05-2007, 12:34 PM
nodrogkam's Avatar
yeah if u didnt already drain it of fluids before you stored it, then you should do it now, fill it back up and do another drain and fill about a hundred miles down the road. I honestly dont see too many problems. Just do an overall visual of everything you can see or feel. And always be sure to check your tire pressure and tire conditions. Tires dry out and crack over the course of the years even if your car has been sheltered.
take it easy!
bullardjh
03-12-2012 10:22 AM
djsp4380
05-24-2011 07:41 AM
bdogggut34
12-29-2010 11:23 AM
lukaskliz
01-18-2010 10:53 PM
Quick Reply: Car Sat fro 3 1/2 years What do i Do??
