Camry V6 95 3VZ-FE - occasional low rpm misfire
I have a Vienta 1995 V6 3VZ-FE Manual with 220,000kms
The carmisfires at low rpmevery couple of kilometers. It is a single brief cough/stutter, as though a cylinder hasn’t fired.
It only happens below 2000rpm, and tends to happen when the engine is under heavy load – e.g. driving up a hillin too high a gear.
At high revs the engine isperfect.
There are no ODB codes.
Plugs are new
Leads are new
Distributor cap and rotor are good.
Any ideas what to check next?
Plugs are new
Leads are new
