Sponsored by:
Sponsored by:
code 52 on a 93 4cyl Camry
Old 07-21-2008, 06:34 PM
ericg's Avatar
Default code 52 on a 93 4cyl Camry
I checked the knock sensor on my 93 Camry and came up with a reading of 177 ohms. The book says it should be higher than 1M ohms. I used a regular digital volt ohm meter. Was the meter sensitive enough? Is there a special meter to diagnos a bad knock sensor? Thanks......
Eric
Old 07-22-2008, 06:37 AM
pedro's Avatar
Default RE: code 52 on a 93 4cyl Camry
Are you sure you had the proper range set on your DVM and understood how to read it? Where was the decimal point?
Old 07-22-2008, 06:45 AM
ericg's Avatar
I used a Fluke 77 meter and put it on the auto range mode. In the auto range mode, it read 177 ohms. When I went to the "M" scale manually, it read "000"
Old 07-23-2008, 01:36 PM
pedro's Avatar
Old 07-23-2008, 08:34 PM
ericg's Avatar
Thanks Pedro for the information. It makes it much easier too understand.
Eric
Old 07-28-2008, 02:10 PM
ericg's Avatar
Update: I replaced the sensor and the car is as good as new. I cannot believe how expensive the sensor was from Toyota ($171.00).
Eric
KEVAUG
06-17-2012 08:01 PM
calderondean
07-31-2010 09:53 PM
clark1032@bellsouth.net
07-27-2010 09:48 AM
bayarea2VZ-FE
04-27-2010 07:13 PM
mgoofy24
09-24-2007 04:56 PM
Quick Reply: code 52 on a 93 4cyl Camry
