Cooling system diagram? 89 4 cylinder - Camry Forums - Toyota Camry Forum
Thread Tools Search this Thread
Old 11-04-2007, 01:17 PM
Default Cooling system diagram? 89 4 cylinder
The cooling system on this 4 cylinder has so many extra tubes it's insnane. And from what i'm used to, the thermostate is on the wrong side of hte cooling system!
Anywho, can someone explain or point me to a diagram?
Also, I'm having heat issues, no heat. I've check the heater core line and fluid flows easly, however the lines never get "warm" after the motor is hot. This leads me to believe there is no flow to the core, hence no heat.
I pulled apart the deal on the cylinder head with all the thermotats and no blockage.
Now I'm confused as to how and were and whitch way the collant flows..
I'm assuming it may be a water pump, and I have no intentins to replace that. I'll sell this POS first. replacing the timing belt last year was a major headache.
I've also replace the theormo state and radiator recently. so I don't think it's either one of thoses.
Thread Thread Starter Forum Replies Last Post
1993 camery cooling system rjc General Tech 11 06-04-2014 11:25 PM
Cooling System Quirk bravozulu Engine & Internal 6 11-25-2011 05:54 PM
Cooling system 05cam Engine & Internal 4 05-18-2011 09:15 PM
Please Help with Cooling system Questions bntnd General Tech 4 09-30-2010 09:48 PM
1995 Camry exhaust system diagram BrandonBrutality Headers, Intake, & Exhaust 1 08-27-2008 11:49 PM
Tags
89, 94, 97, camry, coolant, cooling, core, diagram, flow, giagram, heater, line, ranger, system, thermostat, toyota
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
