92 Camry stalling
Old 10-15-2007, 04:05 PM
kristi22's Avatar
Default 92 Camry stalling
Ok so I just got a 92 camry. I got it cheap and knew there was work to be done to it...seemed like a good idea at the time. I took it to the mechanics, it drove fine when I picked it up, the nexy day it started stalling. The mechanic says its not the EGR valve but isn't sure what is causing this problem, it is getting really annoying and I need help! Any suggestions on where to start to figure out what the problem is? Please?
Old 10-15-2007, 06:06 PM
pedro's Avatar
Default RE: 92 Camry stalling
There is a bunch of stuff discussed here. I would start with a search for "stalling". It can be a number of simple things other than the EGR that your mechanic should be able to troubleshoot. You will need to test parts to see what is the problem - no magic to it.
snflwr
01-28-2008 02:43 PM
carmine34
11-02-2007 12:03 PM
tdauber
07-29-2007 07:57 PM
92camryle
12-26-2006 10:29 PM
jmhowe
10-24-2006 03:49 AM
Quick Reply: 92 Camry stalling
