Go Back   Camry Forums - Toyota Camry Enthusiast Forum > General Toyota Camry Forums > General Tech
Sign in using an external account
Register Forgot Password?
Search
submit to reddit
LinkBack Thread Tools Search this Thread
Old 11-15-2010, 11:15 PM
Default Dash lights ( instrument cluster) dont work when lights are on
Last week, my dash smelt like metal was burning inside of it. Now, when I turn on the head lights, the dash lights do not illuminate. However, when the headlights are not activated, the lights work. any ideas?
This ad is not displayed to registered members.
Register your free account today and become a member on Camryforums!
Old 11-16-2010, 11:40 AM
Year of car, does the car have daytime running lights, Canada or US car?
__________________
Joey P
Old 11-17-2010, 06:31 PM
car is 93 camry, USDM, has II ( daytime running lights). The cluster Dimmer doesnt work, and the cluster has no backlighting, however, the blinkers, gas light, o/d light ect work as well as the Clock. strange. Your input is appreciated
Old 11-17-2010, 09:00 PM
Does the glove box light work normally?
Do the dash lights work when the light control is tail position, this being the position right before the headlights ON position? If so, does the dimmer work?
Can you narrow down the smell, are you sure it is under the dash. Could it possible be in the area of the upper left side kick panel?
__________________
Joey P
Old 11-26-2010, 12:48 AM
the dash lights work when in position II ( tail light position/ position before headlights)
glove box light works normally
I dont recognize a foul smell on the left kick panel nor any signs of melted wires
Old 11-29-2010, 05:05 PM
toyomoho, what do you think
Old 11-29-2010, 07:43 PM
Does the dimmer **** control any of these lights, ash tray, cig lighter, rear window defogger, radio, transmission indicator light on dash and shift lever, heater, blower?
If glove box light works power is getting to the lights (although they may not be working).
The dimmer is wired between all the lights that can be controlled by it and ground. Meaning the dimmer is at the end of the circuit after the light bulbs. Between the bulbs and ground.
The glove box receives power from the same power source the dimmer lights do but has its own ground. Thus not controlled by the dimmer.
All the bulbs are powered by the Tail relay, then the Tail fuse. The Tail relay is controlled by the headlight switch. The relay is controlled by an integration relay that is under the dash.
I posted some info for you in a private message.
__________________
Joey P
submit to reddit
Tags
93, backlight, bulbs, camry, cluster, dashboard, dashlights, dont, indicator, inside, instrument, light, lights, shft, work
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
