Sponsored by:
Sponsored by:
Is this supposed to be lit?
Old 03-28-2007, 04:47 AM
SomePunk's Avatar
Default Is this supposed to be lit?
I have an 04 Camry Le and I was wondering if the heating and a/c controls are supposed to be backlit. Mine aren't, and I wish they were.
Old 04-03-2007, 03:21 AM
toyoboy's Avatar
Default RE: Is this supposed to be lit?
yes it should be...make sure your illumination or dimmer control is set bright enough. if thats ok the bulb is out.. ormay nothave power...
Old 04-04-2007, 03:46 AM
nodrogkam's Avatar
most likely you have blown bulbs, but im suspicious of such a new car having blown interior bulbs. Could be a connection problem or bulbs got loose. My 97 has one loose bulb that will come back on if i tap or smack the unit. Hopefully you don't have a short.
Old 04-07-2007, 01:50 AM
SomePunk's Avatar
Well everything else is lit, so I know it isn't the dimmer control. Must be a bad bulb then. I just didn't want to start taking things apart to get there and find out it doesn't even light up. Thanks guys
trueblue94le
10-16-2007 11:40 AM
Quick Reply: Is this supposed to be lit?
