Driver side window only goes halfway up - Camry Forums - Toyota Camry Forum
Thread Tools Search this Thread
Old 07-05-2016, 12:24 PM
Default Driver side window only goes halfway up
The other day I went to put my windows up and the front driver side window stopped about halfway. The window has no problem going up and down from the halfway point but it will not go up all the way. Once it gets near the top of the "limit" it seems like the window starts to go off its track and separates from the molding. Here are some pictures to help. (Excuse the plastic covering, had a lot of rain this weekend.)
Any ideas what it could be?
Edit: 2000 Camry LE
Old 07-05-2016, 08:16 PM
Pictures?
Try lubing the track with a silicone spray.
Remove the door panel. Watch the window regulator in action and where it connects to the lower part of the window. Could be something is broken or binding causing the window to tilt and go off the track.
Thread Thread Starter Forum Replies Last Post
"Check VSC system" only on startup goes off after. GRiDy General Tech 2 10-13-2013 09:02 AM
After replacing the motor, my sunroof closes halfway Diamond Monaco DIY - Do It Yourself 1 06-23-2013 09:29 AM
1999 Camry Driver's Side Window Not Working jmac247 DIY - Do It Yourself 0 05-31-2009 11:57 AM
Driver side window does not work - 98 Camry MattS67 ECU & Electronics 1 01-12-2009 09:59 PM
Driver side window rolls up but takes forever 99CamryLE General Tech 6 01-11-2009 10:00 PM
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
