Sponsored by:
Sponsored by:
was driving my 02 camry today and
Old 08-16-2007, 08:56 PM
nuttintoaboss's Avatar
Default was driving my 02 camry today and
i was driving home tonight when i hit a pot hole and right there all the lights on my dashboard went out the ac lights the gauges and the at shift **** lights went out, obviously something is loose but what someone please help.
Old 08-16-2007, 09:14 PM
nodrogkam's Avatar
Default RE: was driving my 02 camry today and
that must have been one hell of a pot hole. your allignment needs repair too after something like that.
you can check the fuses under the hood and also the ones behind the little storage cubby by your left knee/shin area. the fuses are behind that cubby, you typically will have to remove that cubby to access the fuses, and a diagram should be stickied on the back of that cubby you remove.
Old 08-20-2007, 06:46 PM
kam i did that and it turned out to be the fuse i replaced the fuse and worked perfectly but then driving along after 5-10 minutes it the panel lights shut off on me again i believe the fuse blew again and i used the proper fuse 10A what could that be? is it just something loose? hopefully nothing to be worried about.
Old 08-20-2007, 08:57 PM
nodrogkam's Avatar
so we discovered its a fuse, but now that even replacing the fuse doesnt work, it means you have a short, and the fuse is saving your stuff from frying/catching fire.
SO either u take it in to the shop and pray they find the problem fast and not charge u tons of labor, or u can go find the cables leading to and from the fuse box and figure out whats loose or where wire is exposed and touching causing a short.
Mach2
04-02-2013 08:41 PM
Willem Lee
12-21-2011 03:49 AM
jamesbond
06-03-2010 10:22 AM
Shawn98408
03-26-2010 09:29 PM
calibeep
06-04-2008 09:42 AM
Quick Reply: was driving my 02 camry today and
