egr code problem??
Old 11-17-2008, 06:09 PM
antser's Avatar
Default egr code problem??
hey fellas,
new to this forum and pretty much camry's. im a nissan finatic, but still an enthusiast. i have a 96 camry le with a 3.0 in it. the check engine light came on and i was told it was excessive flow in the egr system. i replaced the egr valve and reset the ecu. it threw the same code at 39 miles later. im not really sure what else to look for. any ideas on the next step. any help is appreciated. thank you
Old 11-18-2008, 06:18 PM
Default RE: egr code problem??
Check that the VSV valve that controls vacuum to turn the EGR valve On/Off is not stuck open.
Check the EGR valve position sensor.
Check wiring for both.
awbooth
05-30-2021 03:40 PM
bigjeep2005
05-20-2011 10:56 AM
bayarea2VZ-FE
04-27-2010 07:13 PM
camrycoupe
09-03-2007 12:12 AM
lavalleemike
05-13-2006 01:46 PM
Quick Reply: egr code problem??
