Sign in using an external account
| Register | Photos | FAQ | Members | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Vendors | TSB & Recalls |
LinkBack | Thread Tools | Search this Thread |
Years 1992-1996 were the same generation.
The engine was used until 2001. The switch works by changing the routing of the vacuum coming in from the "T" port to either the side port or the filtered port (on the "T" side). Bring the old switch with you to compare plus the meter.
__________________
Joey P |
Quote:
So, this switch was used in all 1MZFE engines through all makes? fyi, I guess this switch has been on its way out for quite a while as sometimes it took weeks or even a few months before the mil came back on. It's only lately that the fault has been a steady pita. I've removed the switch for now (until a suitable part is rounded up) and just temporarily connected the 2 vacuum hoses together -- I don't think this will this cause damage to any parts of the engine, cat converter or O2 sensors ..can you confirm this
Ops, if 1MZ-FE the engine was used until around 2005ish.
I don't know if the same part was used throughout the years. The Rockauto website my list the part, if so you can compare part numbers between years. If you bypass the VSV, the EGR system will be ON all the time. This should not damage anything but the engine may not idle very well. EGR system turns off when engine cold, at idle, full throttle, RPM above 4200ish, light engine loads.
__________________
Joey P |
Quote:
![]() Amazingly, the engine seems to run smoothly, albeit with a surge ..it can jack-rabbit with the touch of the gas pedal. This is part of the reason I have ignored the problem light until now that I have more time for it. Gonna check out a wrecker this week and see what they have for replacement. As there are 3 switch valves on the v6 (for different apps), will any of those other switch valves work in place of this particular one -- just in case I can't find the correct one ..or it's damaged on-site? Any other related stuff I should consider grabbing while there? Last edited by Dale; 10-04-2010 at 01:39 PM. |
Manual states possible problem areas are:
EGR valve stuck open VSV or wiring Computer (Seldom goes bad)
__________________
Joey P |
Quote:
I managed to find a used VSV and replaced it (it's solenoid section was open) into the EGR system. I guess I should have just left the MIL light on and let the car cancel when it ran through its routine, but I forgot that step and manually cancelled it via the OBDII interface (laptop). So far, so good -- no dash light has come back on
Great!
__________________
Joey P |
| Tags |
| 0402, 1mz, 1mzfe, 2002, 95, bypass, camry, code, egr, erg, excessive, location, p0402, po402, toyota, wiring |
