Sponsored by:
Sponsored by:
Old 08-28-2015, 04:56 PM
How-Tos on this Topic
Browse all: Steering & Suspension
Print Wikipost
Engine Light Codes P0440, P0441, P0446
Old 11-06-2011, 01:03 PM
Depends on year of car.
One side of the connector on the valve has a plastic tang. One side of the tang is sloped to allow the plug to slide up and over it. In the link below the tang is between the two plastic arms sticking out on the bottom of the plug.
More Information for AIRTEX / WELLS 2M1055
You need to pull up the plastic catch on the plug to get it over the tang.
In theory pressing on the back end of the plug (squeezing the plug) causes the catch to pivot and move up.
Suggest you look at other plugs on the cars such as for VSV valves which might be the same and may allow you to actually look at the plug close up as you attempt to pull of the harness plug.
rocco123
11-18-2014 11:26 PM
kumarjayesh
03-20-2014 10:13 PM
francis1
11-30-2013 12:51 AM
colsoncj
10-03-2012 11:35 PM
selanac
09-02-2011 03:55 PM
Quick Reply: Engine Light Codes P0440, P0441, P0446
