Go Back   Camry Forums - Toyota Camry Enthusiast Forum > General Toyota Camry Forums > General Tech
Sign in using an external account
Register Forgot Password?
Search
submit to reddit
LinkBack Thread Tools Search this Thread
Old 08-30-2006, 11:53 AM
Default How to install new pcv valve
I'm guessing replacing the pcv valve is pretty routine, but I don't have a service manual for my 95 Camry. Anything I need to be aware of when replacing the pcv valve?
Thanks.
This ad is not displayed to registered members.
Register your free account today and become a member on Camryforums!
Old 08-30-2006, 05:03 PM
Default RE: How to install new pcv valve
nope just pull it out and install a new one.
__________________
Mike
Old 12-19-2006, 01:24 AM
Yup, lavalleemike's right, that's all you have to do.
__________________
No Mames!
Old 01-31-2007, 04:57 AM
Make sure that you replace the grommet as well. I have a 98 Camry 4 cyl. and when I pulled the old PCV valve and put the new one in, the grommet broke, the top half on the new PCV valve, the other half down inside the valve cover.
I tried to get it out from the valve cover, no luck. I just left it in there, got a new grommet and put the new PCV valve in. Car runs ok.
Old 01-31-2007, 03:34 PM
always check that the grommet is still soft before you place new one. my rule of thumb, i change pcv every 30k grommet evey 60k. they get brittle. and you don't want it break off.
submit to reddit
Tags
1998, 2006, 91, camry, change, cylinder, grommet, install, le, loaction, pcv, replace, replacement, toyota, valve
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
