How to loacte the 3 rear spark plugs on a 6 cylinder
I have a 2003 camry with 6cylinders. I can loacte the 3 front spark plugs but I can not loacte the 3 rear spark plugs. Any help will be appreciated.
Thanks,
RMS
Thanks,
RMS
RE: How to loacte the 3 rear spark plugs on a 6 cylinder
You may have to moved the intake plenum... follow the spark plug leads - I can see mine? They're a pain in the ar$e to get to... so replace them with some iridium plugs... won't have to touch them for another 80k mate.
the rear 3 are somewhat difficult to get to especially if you dont have small hands/arms. but follow the wires and you'll find them. my rear 3 banks on my 1mz-fe are just plugged, so there are no bolts to remove, just pull and they pop out, then you need a socket extension to reach in and remove the plug.
just a bit of insight, just replace whatever you remove, dont try and go with a different brand or different kind. For this engine stay away from Bosch unless you want a high probability that you'll have some sort of rough idle...(not that toyota would have that pre-installed anyways).
Yes, this makes the simple task of spark plug replacement a total p.i.t.a !! . Good advice given already, so I can just confirm that you will need some extensions and take some yoga classes to get some flexibility in you first . I wouldn't take off the intake or anything, you'll just make more work for yourself and possibly botch something up in the process .
