IAC Valve problem???
Old 09-18-2008, 10:47 AM
jones100001's Avatar
Default IAC Valve problem???
99 Camry 4cyl w/ 220k miles. Car started having rough idle problem. Checked plugs, caps, rotors, etc. I've read that IAC valve problem is common. With the car on and valve unplugged, car idles very low. When the valve is plugged in, car idles higher (still rough) but I hear air chocking sound coming right where the IAC valve is. It's very noticeable w/ the intake tube off. Does this sound like I need a new IAC valve?
Old 09-18-2008, 01:33 PM
pedro's Avatar
Default RE: IAC Valve problem???
What idle rpm are you getting? At 220k miles I'd do a compression test for rough idle. You could also pull one plug wire at a time to see if roughness stays the same or gets worse. That may isolate it to one cylinder.
Old 09-19-2008, 08:10 AM
car also threw a code P0505
Old 09-19-2008, 08:17 AM
Code is for IAC valve. Stuck or closed IAC valve-circuit problem, problem A/C circuit or loose air intake hose.
Old 09-19-2008, 08:56 AM
tried to clean w/ some carb cleaner as suggested by a member but that didn't help. I hear alot of hissing sound coming from it.
Old 09-19-2008, 09:04 AM
pedro's Avatar
ORIGINAL: jones100001
Check for vacuum leak other than IAC.
Old 09-19-2008, 02:57 PM
PyrMan3's Avatar
carb cleaner usually spells death for the iac, u most likley have a leak, ad now need a new iac
Old 09-19-2008, 05:50 PM
new spark plug wires solved the problem
toyotafan111
07-21-2017 01:20 PM
brianjrealtor
07-09-2012 10:54 AM
brianjrealtor
08-21-2011 10:56 AM
brianjrealtor
06-04-2011 09:44 PM
ant7701
10-02-2008 07:14 AM
Quick Reply: IAC Valve problem???
