Go Back   Camry Forums - Toyota Camry Enthusiast Forum > General Toyota Camry Forums > General Tech
Sign in using an external account
Register Forgot Password?
Search
submit to reddit
LinkBack Thread Tools Search this Thread
Old 06-05-2011, 12:19 AM
Default IAC valve removal and cleaning questions...
1993 Camry LE...
If I want to remove the IAC valve and clean it....
Here is a link to a pic for the exact part on my camry...
toyota camry Fuel Injection Idle Air Control Valve Standard Ignition
it seems easy to remove with only 4 bolts holding in place.
1) after unscrewing the 4 main bolts and removal of the IAC valve from the car, should I also unscrew the philips head screws and clean inside the plastic electrical housing portion of the valve?
2) to test the valve after i clean it before reinstalling, what leads of the elctrical connector are negative and positive? I'm thinking I can run wires from a 9v batter to connect to the electrical leads and see the interior parts move? (I had used a 9V battery and 2 wires to test the VSV valve once before for opening and closing and this method worked great, so I thought the 9v battery could be applied for easy testing on the IAC valve as well?)
3) If i cannot find a new IAC valve gasket at the parts store, can i still use the existing one?
thanks!
Brian
This ad is not displayed to registered members.
Register your free account today and become a member on Camryforums!
Old 07-08-2012, 03:51 PM
upupup
Old 07-08-2012, 11:13 PM
I find it easy while watching doing it on the vid but is seem so hard to apply I haven't tried it yet.
Old 07-09-2012, 10:54 AM
Looks like mine needs a.new gasket.
submit to reddit
Tags
03, 2003, 93, 97, ac, air, camry, clean, cleaning, control, iac, idle, removal, toyota, valve
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
