Sponsored by:
Sponsored by:
LOTS of WATER in the trunk
Old 11-14-2007, 11:40 AM
JBoivin's Avatar
Default LOTS of WATER in the trunk
Well, as I have previously introduced myself, I have a 2000 Camry LE and I have a little system and was planning on doing fiberglass in the trunk. Well, as I was taking everything out, I got to the left side of the trunk, the part where it dips down and can be used as storage, I find the whole thing full, and another thingI found was a big square hole, not rusty, a manufacturer hole, and a popped out vent it looks like. It's a little box, with rubber flaps, I don't know...., I guess you guys should check out and see if yours are doing the same thing. Also I tried putting the vent back in and it just won't stay. The right side doesn't have the same vent, that's the side where the jack is. So I checked everything over and there's no rust holes and where everything is sealed it's all sealed no breaks or anything, so I'm guessing water is coming through the vent. So I just stuck a towel in there and hopefully seing that it rained today, we'll see if theres any water, just letme know if any of this has happened to any of you before.
Old 11-15-2007, 10:12 AM
JBoivin's Avatar
Default RE: LOTS of WATER in the trunk
I'm guessing no one.
Old 11-15-2007, 11:44 AM
pedro's Avatar
Got a picture or two?
Old 11-17-2007, 02:05 PM
Vic7's Avatar
I've gota 01' LE and when I first got it back in Jul 04', I had the same problem...water in the same place, but the water was leakingfrom the tail light. I simply bought a rubber washer for the tail light bolts and problem solved. Hope this helps.
Masterwood55
03-04-2014 08:39 AM
sjoefl01
03-01-2014 11:23 PM
simon949
04-02-2013 02:58 AM
rwyatt80
08-10-2009 09:32 PM
camryredneck
11-17-2007 06:29 PM
Quick Reply: LOTS of WATER in the trunk
