Sponsored by:
Sponsored by:
Need Help
Old 01-10-2017, 04:19 PM
Matthew Mckenzie's Avatar
Default Need Help
What's up guys, I have a little problem is was trying to flush out my radiator or old engine coolant and in the process I broke the drain plug ( plastic is too brittle). Now I cant turn the plug so I can make the coolant drain. I was thinking to remove the whole radiator and then try to saw it off, melt it off, or drill into it. What do you think ? I have pictures if you guys want to see.
Old 01-11-2017, 12:58 PM
Once you get the radiator out you can look more carefully at the plug. Then use the same methods as for removing broken bolts.
You might be able to use a soldering iron or a heated blade to carefully melt a slot in the plug head for a flat blade screwdriver.
A bigger concern may be finding a replacement plug. I suggest you work this issue first.
rlmeredith
08-21-2012 07:33 AM
sv21
04-30-2009 12:52 PM
ToyotaMan55
06-06-2006 01:51 PM
SymtecX
02-27-2006 03:00 AM
cam03TRD
08-21-2005 06:55 AM
Quick Reply: Need Help
