Browse all: Exterior
- Toyota Camry 4th, 5th, and 6th gen Why is Car Squeaking
Guide to diagnose trouble and recommended solutions.
squeaky back doors
squeaky back doors
when i go to open or close the back doors of my 94 camry, they squeak loudly. i have tried ilicon spray onthe doors moving parts. car smells like lubricant and the doors still squeak.
any solutions or thoughts?
RE: squeaky back doors
Typically white lithium grease is used on hinges (which is where the squeeking is coming from). I don't thinkit really smells at all and it lasts a long time. You should probabley clean the silicon off first to make sure the lithium really gets into the hinge
ORIGINAL: mjnrite1
On my car, a '98 Camry, both the front driver and front passenger doors squeak just immediately before closingand immediatelyupon opening...they do not squeak at any other point in the range of motion of the door. I isolated it toa 1/2" portion of thedoor frame rubbing directly against part of the weatherstripping.
Solution: apply a silicone-based rubber/vinyl/plastic conditioner to the weatherstripping. Ineed to re-treat this area about three times per year to silence the squeak sincethe conditionereither gets absorbed by the rubber or just runs/wears off over the course of several months.
ORIGINAL: 93camryxle
To follow-up on my previous post,this isthe product that I happen to be using this year.
http://www.blackmagicshine.com/produ...ine-protectant
I have also had good results from Meguiar's products as well.
I have no interest, financial or otherwise, in promoting either of these two companies' products.
whyandwhat4
05-08-2014 09:44 AM
